1967 Pontiac GTO i have no clue whats going on?
57,000 MILES • V8 • 2WD • AUTOMATIC
JOHNWHITE1986
my 67 gto will not turn over it will only click, i have replaced the starter, the alternatior works and has been tested and the battery us fully charged. i am not sure what the problem is i drove the car a few weeks earlier and everything was fine. what could be the problem?
Nov 4, 2009 at 8:27 AM
  • 31,937 POSTS
Hi there,
Remove the battery terminals and clean and make sure that they are making a firm contact when re tightened , check the voltage at the starter when cranking, there should be 12V at the solinoid terminal (the small wire) and there should be constant voltage at the mail terminal (heavy wire) if this is so and the starter solinoid is clicking, the starter is faulty , you have checked that the engine is turning over by hand?
Mark (mhpautos)
Nov 4, 2009 at 8:54 AM
  • 75,988 POSTS
Battery and connection okay -check and test the neutral safety switch and ignition switch
Nov 4, 2009 at 9:00 AM
