1966 Pontiac GTO ignition
KERRY MAHON
Electrical problem
1966 Pontiac GTO V8 Two Wheel Drive Automatic
What wires do I put a jumper on the key ignition switch connector in order to by pass the key switch to start the engine,so i can see if the key switch is faulty?
Feb 13, 2010 at 7:04 AM
HMAC300
  • 48,601 POSTS
just put a test light on the coil to see if you aregetting power there. If you have a clutch, the clutch pedal must be depressed in order for the car to start. And if it's an automatic your nuetral safety switch could be bad. YOu have to check that stuff first.......
Feb 24, 2010 at 9:41 AM
