I have a 1965 gto with an LS 2 with T-56 6 speed, moser 9" ford rear with 389 gears. I have baer brakes (track style) metco aluminum control arms (upper adjustable). I have a vibration around 65- 70 miles per hr. on up, never goes away. I have adjusted my pinion angle from +3 to -3. I keep going through rear axels bearings where the rear end grease penetrates the bearing. To stop the vibrations I have replaced the the axels, tires, rims, bearings, driveshaft, universals, center section, and housing. The t-56 tail shaft bushing is tight and there is no seal leak (8500 miles) No broken motor mounts. Drive shaft is balanced. what do you think? thanks steve
Oct 30, 2009 at 10:30 AM
