1975 Pontiac Grandville wont start
1975 PONTIAC GRANDVILLE
159,000 MILES • V8 • 2WD • AUTOMATIC
COCKY1
drove threw high water and stalled already did all the regular stuff but still wont start
new parts are:
ignition control mod
plugs
cap
roder
what am i missing?
Jul 6, 2010 at 8:46 PM
but still wont start , Verify if you're getting fuel and spark do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 6, 2010 at 11:20 PM
