1999 Pontiac Grand Prix Wiper Stops Halfway
RBROWN84
yes i have a 99 pontiac grand prix with about 75000 miles on it and it is a v6 believe. my question is when you turn on the windshield wipers the go up together but on the way down on only goes half way down and th other goes all the way down and when it starts to come back up they both do except the one that only goes half way down shoots over and lays on mirror.
Jan 27, 2007 at 5:27 AM
SERVICE WRITER
  • 9,123 POSTS
good chance the post where the wiper arm is nutted down is loose or stripped. may have a wiper transmission problem. Pry off the cap over the wiper arm pivot point and check the nut for looseness.
Jan 27, 2007 at 5:29 AM
QUEENREDBULL
  • 6 POSTS
That is kind of funny. I have a 93 Grand Am and it does the same thing. A friend of mine had riged it with a rope and it hasnt done it again yet!! Good luck At least I know now what the problem could be drom reading the responses from your question.
Feb 2, 2007 at 5:18 AM
SERVICE WRITER
  • 9,123 POSTS
Get it taken care of before it strips the friction grooves and you need new arm.....or a new rope :lol:
Feb 2, 2007 at 6:26 AM
Suggested Repair
Pry off the cap at the wiper arm pivot and check whether the nut is loose or the post is stripped. Tighten or repair it before the friction grooves strip and a new arm is required. A wiper transmission problem is also possible.
Conversation Summary
The owner of a 1999 Pontiac Grand Prix said the windshield wipers rise together, but on the way down one stops halfway and then swings over onto the mirror. The expert said the wiper arm pivot nut may be loose or stripped, or the wiper transmission may be faulty, and advised checking the nut under the pivot cap before the arm's friction grooves are damaged.
