Will not crank over
130,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
CIVERSON
Changed out the radiator with brand new one. After put back together and all fluids we added. Tried to start the car. All lights turned on with the ignition on switch of the key. There is one click sound and no crack.
Battery is good.
Starter is getting enough voltage.
Computer will not read - figuring an electronic cancer but if so which one?
Feb 3, 2019 at 2:10 AM
SCGRANTURISMO
  • 4,897 POSTS
It sounds to me like your starter is going bad or has a flat spot in it. Here is a helpful link:
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
If the starter needs to replaced:
Let us know if there is anything else we can help you with. Thanks
Alex,
2CarPros
Feb 4, 2019 at 4:04 AM
