Wet pontiac grand prix. HELP!!!!!!!
RICHSAXTON
I have this 1998 GP that is driving me absolutly crazy!! If there is moisture in the air, or it is raining.This car does not want to run. It runs very rough, rich it seems. It will idle irraticlly, stall, and the exaust pipe will turn red hot, as well as the catalytic convertor. When I put it on a diagnostic tool it said that the mass flow sensor was bad. I have taken it to many differant mechanics including GM. No one can seem to figure this out. I have replaced the sensors, catalytic converter, fuel filter, plugs, wires, and ect...When I replaced the o2 sensor the wires were burnt. The insulation on the wires had melted. I replaced them as well, but I then realized that the wires that connect to the o2 sensor might be melted as well so I checked them. Just as I thought they had been burnt. I DID MY BEST AT INDIVIDULLY TAPING EACH ONE, THEN TAPING THE BUNCH TOGETHER.The wires run up into the engine compartment, I taped them as far as I could. So I am wondering if maybe that might be the problem. If so do I have to purchase the complete engine harness? Does this sound like that might fix the problem? If so how would I go about doing this? Any help, or feedback would be greatly appreciated. Rich
Mar 30, 2007 at 5:38 AM
MCFERRANCE
  • 100 POSTS
If the wires were hot enough to melt the insulation, they have probably gained a lot of resistance to carrying any electrical signals. These can be tested with an ohm meter. If they look anything other than shiney copper, they probably have been damaged and need replaced.
Most likely the best bet would be to find a salvage yard and splice the harness. If the plug is ok at the O2 sensor, you may be able to splice it and replace the burnt wires as necessary.
However, this problem may only be a cause of the original problem, but you have to start somewhere.
Mar 30, 2007 at 7:16 AM
RICHSAXTON
The only thing is that I dont know if I can reach up to where the wires need to be spliced. Maybe if I trace the wires back up to the top, or back side of the engine I can replace it there? when I taped them, they where tucked and melted into the heat sheild. I could only reach some of them. Once it made the curve back to the engine, is where I had the problem. If you know of a way that I might be able to do this I would, greatly appreciate the advice. Thank you again! Rich
Mar 30, 2007 at 11:41 AM
