1999 Pontiac Grand Prix One-Side A/C
PRFXSHN
I have a 1999 Pontiac Grand Prix 3.8 (non supercharged model) with about 178K miles on it. I have never had a problem with this vehicle until now. I have the dual-climate control in my vehicle (passenger side can be set to a diff temp than drivers side). My A/C works on the passenger side but not the drivers side. I do think I have a small leak off of the a/c compressor as well. I don't think the leak on the compressor would cause only one side of my a/c to operate (the passenger side). Any suggestions on what would cause this problem? If I want to run my air conditioning, I have to deal with the regular air (hot as hell) blowing on me while the passenger side if dealing with nice a/c. Thanks for the help ahead of time!
Jun 8, 2007 at 11:59 AM
CHEVY22
  • 1,375 POSTS
HAVE IT CHECKED FOR LEAKS FIRST , THE EVAP CORE AND COLD AIR ARE ON THE PASSENGER SIDE , ALSO CHECK TO MAKE SURE THE BLEND DOORS ARE ALL WORING PROPERLY , YOU SHOULD BE ABLE TO HEAR THEM WHEN TURNING VENT CONTROLS , BUT MY BET IS YOU HAVE A LEAK
Jul 22, 2007 at 2:12 AM
Suggested Repair
Check the A/C system for leaks first, including the evaporator core, since cold air is produced on the passenger side. Also confirm the blend doors move properly and can be heard when the vent controls are changed.
Conversation Summary
The owner of a 1999 Pontiac Grand Prix with dual climate control reports that the A/C cools the passenger side but blows warm air on the driver side, and suspects a small compressor leak. The expert recommends checking for leaks first and verifying that the blend doors operate correctly, with a leak considered the most likely cause.
