Part Identification
DBSWEENEY
Pontiac Grand Prix auto 38k miles.
On the driver side. on the rear of the manifold just under the EGR valve is a small black part with a couple wires connected to the top and small hose running back to the firewall and down towards floor. the hose is wrapped in black flex cover.
What is the name of this part, and how do I replace? the tube leading out of it is broken and it is giving check engine light and check gas cap.
Thanks
I can upload a picture later if requested.
thanks in advance
Dan
Nov 7, 2007 at 11:16 AM
BLACKOP555
  • 10,386 POSTS
would like a picture of the part if possible.
Nov 7, 2007 at 11:43 AM
DBSWEENEY
this 1st picture is taken from drivers side with the plastic cowelling pulled back. second picture is wider angle of same. see red arrow on both - pointing at part. normally, it has a plastic tube connected (which broke off) making a puffing sound. If I cover the hole it stops making the noise. thanks Dan
https://images.2carpros.com/forum/automotive_pictures/114825_mystery_part_1.jpg
https://images.2carpros.com/forum/automotive_pictures/114825_longer_shot_1.jpg
Nov 8, 2007 at 9:54 AM
