If I read this right, you have battery voltage for accessories, just a no crank from the starter? First thig to check is fuseible links at your starter, then the heavy cable to the starter, then the Ignition wire, usually small striped wire, check it between the starter and ignition switch! HaPPY HUNTING. Oh one thing, can the engine be turned with a wrench? May be siezed?
SPONSORED LINKS
Tuesday, September 18th, 2007 AT 6:16 PM
