Hi there,
See if you can get an ignition test done on an oscilloscope, as this will give you all the ignition voltages, you may have low ignition voltage through a faulty coil. And the higher flash point of the starter fluid is the reason it will start on it, look into this next.
Mark (mhpautos)
Saturday, August 9th, 2008 AT 6:49 PM
