What is causing this, and is it simple enough for me to fix it under the shadetree?
1997 Pontiac Grand Prix Fuel Gauge Stuck
Suggested Repair
The fuel sending unit or instrument cluster is likely bad. On this GM vehicle the sender is often part of the fuel pump, so the tank may need to come out to replace the pump and sending unit. Confirm with a parts store whether the sending unit is sold separately, and drive the car until it is nearly empty before removing the tank.
Conversation Summary
The owner of a 1997 Pontiac Grand Prix GT reports the fuel gauge stays at 3/4 and the digital range display does not change no matter how much fuel is in the tank. The expert says the fuel sending unit or instrument cluster is bad, and on a GM vehicle the sender is probably part of the fuel pump. Replacing it typically requires dropping the tank; the owner should check whether the sending unit is available separately and run the tank nearly empty first.
