1994 Pontiac Grand Prix No Start Clicking
Cly
Suggested Repair
Check that the battery cables are clean and tight and that the engine-block grounds are secure. Confirm the alternator wiring was reconnected after the intake gasket repair, and return the car to the shop to recheck anything that may have been overlooked. The clicking and flickering point to a low battery or poor ground.
Conversation Summary
The owner of a 1994 Pontiac Grand Prix says the car had electrical symptoms before an intake gasket repair and now will not start, only clicking while the instrument lights blink. Earlier, the speedometer jumped with the turn signals and brakes, the radio cut out, and the car struggled to move from a stop. The expert suspects a loose ground or low battery and advises checking battery cables, engine grounds, and alternator connections, then taking the car back to the shop.
