A/C blowing hot air and only on max fan setting, need help.
TERRYJD
  • PONTIAC GRAND PRIX
I have a 2000 Pontiac Grand Prix with 137, xxx miles on it. It has been sitting for about 10 months withough being driven regularly. I have gone out and started it once every two weeks since it was parked. I recently decided to start driving it again and now the A/C does not blow cold air and the fan only works on the max fan setting.
I realize there are probably two issues here. I have checked the fuses for the fan issue and it does not seem to be the problem. As I understand it the max fan setting and the other 4 settings are run on different switches? Any ideas on what to do here would be appreciated.
Second issue: not blowing cold air. I have checked the low pressure valve and it read 35 psi which I believe is in spec.
I am not very experienced at this kind of work (A/C), but if it is something I can fix I would prefer to do it myself. I know there are issues regarding A/C repair with EPA guidelines etcetera.
Please Help Me!
Sunday, August 19th, 2007 AT 4:11 PM
2CARPRO JACK
  • 11,533 POSTS
That a/c pressure reading static isnt enough to make the system work, might have a small leak. The blower. There is a fan speed controller/resistor mounted near the blower motor in the HVAC plenum, follow the power wires from the motor backwards to find it. That will solve that one.
Monday, August 20th, 2007 AT 8:07 AM
