95 Grand Prix 3.1 SE ABS and Brake light On
GV77
  • 1995 PONTIAC GRAND PRIX
I have a 1995 Grand Prix SE 3.1 with 153000 miles on it and about a month and a half ago I replaced the alternator and brake pads and I also turned the rotars. Around that same time my ABS light was going on and off. After I finished replacing all of that I noticed that my ABS light just stayed on and its been on ever since. Now, just recently my brake light has gone from going on about every other time I turn on the car to every time. My brakes seem to work fine? I was just wondering what the problem/s could be? Any advice would be gretly appreciated. Thank you.
Greg
Thursday, July 26th, 2007 AT 6:51 PM
GV77
  • 5 POSTS
Anyone?
Friday, July 27th, 2007 AT 7:37 PM
HARDMAN618
Hey bud, I had the same problem for awhile with the ABS light flicking on and off and my friend suggested to me that I check the brake fluid. I refilled it and the light went off and has been off since. Hope this helps.
Cory
Monday, August 6th, 2007 AT 11:43 AM
GV77
  • 5 POSTS
Thanks for the suggestion, but thats one of the first things I tried. I also took it to autozone to run codes but my car is a year too old for that. Anyone else got anything?
Monday, August 6th, 2007 AT 3:53 PM
MERLIN2021
  • 17,250 POSTS
If you turned the rotors, you may have a buildup of steel shavings on you sensors. They are magnetic. Try cleaning the sensors with compressed air. While your at it clean the ring gears too.
Wednesday, August 15th, 2007 AT 6:18 PM
GV77
  • 5 POSTS
Ok will do. Thanks for the advice.
Saturday, August 18th, 2007 AT 6:22 AM
