runs for a bit then dies, after a while it starts again. If you let it run for about ten minutes and shut it off, it wont start unless you press the gas a little bit.
I changed the EGR, throttle positions censor, IAR valve, checked for vacume leeks?
Tuesday, October 16th, 2007 AT 3:23 PM
