2007 Pontiac Grand Prix tie rod
LEDESMA1963
Steering problem
2007 Pontiac Grand Prix Front Wheel Drive Automatic
i need to replace my passenger side tie rod because it is bent, I have popped the ball joint and removed the plastic boot, but I can't seem to pull the tie rod out
Dec 20, 2009 at 3:57 PM
  • 31,937 POSTS
The tie rod end, screws onto the steering arm, back off the lock nut and count the turns the old tie rod unscrews, re fit the new end the same number of turns, nip up the lock nut, and re it the ball end with a new split pin. get an alignment end done.
mark (mhpautos)
Dec 20, 2009 at 5:27 PM
