2006 Pontiac Grand Prix Throttle Problems
71,000 MILES • 6 CYL • FWD • AUTOMATIC
SUBWARRIOR632
I have an '06 Grand Prix, GT, 3800 v6 w/SC. I have two fault codes. P1125 Throttle Position/Accelerator Pedal Position Sensor Ckt Problem. And, P2138 Accelerator Pedal Position Sensor 1-2 Correlation. Based on these two codes I want to jump on the Accelerator Assy and replace it first. I just hate to do "Easter Egg'ing" and would like to know if I should go for the Accelerator Assy replacement or the Throttle Assy, or is it something else?? The problem is intermittent and I also get the "Reduce Engine Power" alarm on the info center and then it runs really bad. Any insight and help is appreciated.
Sep 8, 2009 at 11:43 AM
MMPRINCE4000
  • 8,548 POSTS
I would replace the accelerator assy. Look like $60 from NAPA. You other choice is to take to shop or garage and have it hooked up to high end scanner, which will isolate the faulty part/circuit.
https://images.2carpros.com/forum/automotive_pictures/108325_GP_pedal_sensor_1.jpg
Sep 19, 2009 at 1:07 AM
SUBWARRIOR632
Thanks guys! I already figured out that was the bad part. Although I had found it listed on NAPA's online parts listing, it turned out that they have zero available nationwide. So, called my local dealer and they found one at a Chevy dealership not far from me and it was actually less than the listed price with NAPA. I think it was about $48.00 or so, out the door. Anyway, thanks for the response.
Sep 22, 2009 at 6:01 AM
MMPRINCE4000
  • 8,548 POSTS
Great news, thanks for using 2carpros.
Sep 23, 2009 at 12:36 AM
