2006 Pontiac Grand Prix The trunk will no longer open
BOBACOBB
Electrical problem
2006 Pontiac Grand Prix Automatic
I took it to a shop and they said that the wiring had shorted. I need to know how you can fix the wiring to open the trunk since there is no key entry for it.
Aug 6, 2010 at 4:15 AM
JDL
  • 16,098 POSTS
If you have the folding split rear seats, the seat back folds down to access the trunk. If not, I'd probably remove the rear seat. Your owners manual may have some info on folding down the seatback.
Another thought, if you could access the voltage wire at the rear for the trunk latch, hoping the short is toward the front somewhere, then you could use a jumper for voltage. Don't know how wiring circuit is routed, it could be under the carpet, under door trim, under the vehicle, almost anywhere. If you can find the wire harness at the rear, I can give you the wire color.
Why didn't the shop fix it?
Aug 6, 2010 at 5:45 AM
