p0411 code = secondary air flow
53,000 MILES • 6 CYL • FWD • AUTOMATIC
KDH4962
secondary air injection valve what is the problem most likely?
Jun 3, 2009 at 9:02 AM
BRIAN 1
  • 1,030 POSTS
This means the secondary air control valve needs to be replaced here are instructions and diagrams to help you get the job done. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jun 3, 2009 at 9:37 AM
CHELSEA8807
I have the check engine light on, what kind of place should I take my car to get fixed?These codes have come up on my car for quite some time now. I only know mechanics at transmission shops and they said they cannot figure out how to fix this for me but I don't want to go to the dealer because of how expensive it is just for them to look at it so I am trying to figure out what kind of place would be able to fix this for me while at the same time not charging me an arm and a leg. I live in Albuquerque, NM. Thanks for the help.
Jun 11, 2019 at 9:43 AM (Merged)
RIVERMIKERAT
  • 6,106 POSTS
P0411: Secondary Air Injection System Insufficient Flow. Either the smog pump isn't supplying enough air pressure, or one of the valves in the system isn't operating properly. Most regular mechanics can fix this.
P2430: Secondary Air Injection System Pressure Sensor Stuck in Range. This tells me that both problems are probably a faulty air injection system pressure sensor. Any mechanic. Some Pep Boys stores do this work. You could probably save yourself quite a bit of money by buying a Chilton's or Haynes repair manual at the same store and doing it yourself. The manuals usually cost around $20.
