2006 Pontiac Grand Prix Engine light and leaking
60,000 MILES • 6 CYL • AWD • AUTOMATIC
BILLMC367
I moved my car this morning and found the engine light was on. The engine sounded as though it was running much lower, and then I discovered what appears to be leaking on the road. This leak appears to be coming along the muffler line. Prior to this, my computer was warning to check my gas cap - upon inspection, it seemed to be attached fine.
I am wondering if this is a major repair or an less expensive repair.
Oct 2, 2008 at 11:19 PM
2CARPRO JACK
  • 11,533 POSTS
Condensation gathering in the exhaust is normal, they actually have small drain holes so it can get out of the muffler.As far as the check engine ligth, you will have to have the PCM scanned to see what code it has stored
Oct 3, 2008 at 12:53 AM
