Engine Cooling problem
2006 Pontiac Grand Prix 6 cyl
I just took off the plastic splash covering and I am not sure where I drain the coolant. My father says that you loosen up a screw that is on the radiator on the driver's side to drain the coolant. The problem is, the screw I believe that I should loosen up is under a metal cover that is used to support the radiator.
So to sum it up here are my two questions:
1. Where do I drain the coolant from?
2. Is this metal support a known problem for coolant replacement?
Thanks in advance.
Thanks in advance.
Aug 9, 2009 at 8:42 AM
