2006 Pontiac Grand Prix Both headlamps quit at once.
32,000 MILES • 6 CYL • FWD • AUTOMATIC
COUCHSURF
What would cause both of the headlamps to stop working on a 2006 Pontiac Grand Prix?
The parking lamps come on but no headlamps. The high-beams work but not the low beams.
The fuses are ok, (there is 1 fuse for each lamp). Could it be the low-beam relay? Or if 1 headlamp burns out,do both stop working?
Dec 29, 2009 at 9:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely faulty LO BEAM Relay, located in the underhood fuse block. if relay tests OK, suspect faulty headlamp switch.
Dec 29, 2009 at 5:02 PM
