One of my rear brakes lights has went out. I replaced the bulb and the light still won't work. What should I do now?
Jun 26, 2009 at 7:10 AM
JDL
✓Experienced Mechanic
I believe the turn and lower brake use the same bulb filament, just not at the same time. The bulb in question, does the turn signal work?
Jun 26, 2009 at 7:45 AM
MONIQUEXMAS1
MEMBER
no the trun signal doesn't work either!
Jun 26, 2009 at 8:00 AM
JDL
Just to double-check, I'd use a testlite on the circuit in question, check for voltage and ground with either the brake or turn activated. If there is no voltage, that circuit comes from the bcm. I'm not saying the bcm is faulty, maybe something wrong with the wiring circuit. Check for trouble codes. Just to add, I'd probably check the bulbs front and back, turn.
Jun 26, 2009 at 8:31 AM
