2005 Pontiac Grand Prix oil pressure
2005 PONTIAC GRAND PRIX
74,000 MILES • 6 CYL • FWD • AUTOMATIC
KBTOY
I have a 2005 pontiac grad prix with a 3.8 a while ago the oil pressure gauge began sticking at 120 lbs then it began to fluctuate now it is at 0 where is the iol pressure switch located
Nov 10, 2008 at 12:56 AM
MMPRINCE4000
  • 8,548 POSTS
Switch is under the PS pump.
If you are getting any valve noise have the oil pressure tested with a mechanical gauge.
If not, then I would change the oil pressure switch.
It is also possible the gauge itself is bad.
Nov 10, 2008 at 1:48 AM
