2005 Pontiac Grand Prix blower not blowing out anything
2005 PONTIAC GRAND PRIX
73,000 MILES • 6 CYL • FWD • AUTOMATIC
BAREDAELLI
we changed the fuse and relay fuse still nothing blower does not do anything on any speed how do tell if its the switch is bad or the blower and how do you check which it is without buying both is it something you can change buy yourself? please help
Feb 21, 2010 at 9:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you will have to remove the motor and test it with a direct power source (i.e. 12v wire from battery and ground wire) if motor runs direct connected then check wiring and switch .
Feb 21, 2010 at 10:53 AM
