2004 Pontiac Grand Prix rattle from front of car
2004 PONTIAC GRAND PRIX
101,417 MILES • 6 CYL • 2WD • AUTOMATIC
HODGE458
I have a rattle coming from the front when car is moving only. It is most noticable when driving slowing on a bumpy road. Could it be struts or stabelizer links ?
Jan 31, 2010 at 7:55 AM
MMPRINCE4000
  • 8,548 POSTS
You mentioned two possibilities.
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
With car up, grasp strut cartridge and see if it is loose.
Feb 1, 2010 at 12:44 AM
