2004 Pontiac Grand Prix Lower end failure
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVEZANDER
The 3800 motor in my 2004 Grand Prix started rattling last weekend while I was on a trip of 250 miles. I took it to a local dealer and they found metal chips in the engine oil so it appears that something loosened up internally. About 1000 miles ago, I put synthetic oil and a Mobil One filter in the engine. The mechanic that is doing the engine swap claims that switching to synthetic oil likely caused old oil varnish or other particles to get between the crankshaft and bearings, causing this failure. Have you ever heard of this? I can't find any information suggesting that synthetic oil should not be used in an engine that has run 80000 miles on convetional motor oil.
Jun 9, 2008 at 5:55 AM
DOCHAGERTY
  • 9,606 POSTS
I have had failures with Mobil one in Subaru motors. There is really very little advantage to synthetic in old worn motors, you may well have been at the cause of the motors failure. I have seen these failures and yes they do occur.
Jun 9, 2008 at 6:14 AM
