2004 Pontiac Grand Prix Fuel gauge and shakes when braking
2004 PONTIAC GRAND PRIX
77,620 MILES • 6 CYL • 2WD • AUTOMATIC
LILWALK
My fuel gauge is not reading right. It says it emtpy and the warning light comes on but it not empty. Then it reads full but its not, Also when i brake the car shakes and wobble, any sugesstions?
Sep 11, 2009 at 5:08 AM
MMPRINCE4000
  • 8,548 POSTS
The gauge problem is either the gauge itself, or the sender in tank.
You would have to isolate the wires to the gauge from the sender and measure resistance.
Most GM cars are 0-90 ohms, 0 is empty and 90 is full.
If resistance flucuates, then sender is bad, if not then gauge is bad.
The wobble is most likely a warped rotor.
Sep 12, 2009 at 1:25 AM
