2004 Pontiac Grand Prix engine stalls at startup
67,000 MILES • 6 CYL • FWD • AUTOMATIC
EAGLE_9198
Sometimes when I start my car the engine will turn over for about 2 seconds then it the engine will shake for a second and the engine will stall out. It does not always do this. I have noticed that when it does do this it will do it over and over and over again untill it finaly starts i once tried 6 times before it finaly caught and stayed running . I have found that if it does this, on the second attempt at turning it over, I will rev the engine a little, 1500 rpm is enough, the engine will turn over and then run fine. This problem only happens at startup. once running the engine runs fine with no other problems. I can run all day long with no issues.
I had a tune up done at 60000, all fluids, timing belt, plugs, wires. And I always change the oil every 3-4 thousand miles (mobile 1 5w30 synthetic)
If the engine stalls out like that sometimes can that do any damage to the engnie? any suggestions?
Dec 3, 2009 at 4:42 AM
MMPRINCE4000
  • 8,548 POSTS
Are you getting any codes (error codes)?
It would not mechanically hurt the engine, but pumping raw gas into engine can cause convertor/O2 sensor damage.
You most likely have an intermittent sensor failure. Best fix is to get car scanned and find problem.
I applaud you on your maint. routine, very nice.
Dec 4, 2009 at 12:16 AM
