2004 Pontiac Grand Prix Doors won't lock
STEVE GRONKJAER
Electrical problem
2004 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
My doors won't lock when using the key fob. The horn will sound and lights flash as if they were locking and the alarm is set but the doors don't lock. All other functions from the fob are working such as trunk unlock alarm set and doors unlock.....any suggestions?
Thanx
Jan 26, 2009 at 1:20 AM
MMPRINCE4000
  • 8,548 POSTS
Start simple, replace battery in key fob.
If you can lock/unlock doors using key in door, and buttons inside, then you will probably have to go to GM and have a dealer look at it.
Also check fuses.
Jan 29, 2009 at 2:58 AM
STEVE GRONKJAER
Thanx for the reply...I did replace the batteries in the fob and also went to a Gm dealer who siad they would replace a computer part for $650.00 but wouldn't gauranty it would solve the problem....any help is apreciated!!
Jan 29, 2009 at 10:01 PM
MMPRINCE4000
  • 8,548 POSTS
Try finding the part GM said needed to be replaced at a junk yard. Only problem with this is that it will probably have to be flashed to your VIN, by GM.
Jan 31, 2009 at 1:44 AM
