display information out check fuse and they are all good what can i do next thank you
Jun 5, 2010 at 5:36 PM
MMPRINCE4000
✓Experienced Mechanic
Have dealer diagnose problem, if HUD is bad, look for one at junk yard.
Jun 6, 2010 at 12:23 AM
CRAIG4465
MEMBER
Its the spring. you need to remove the hud from the dash and pull it apart and drill a hole near the old hole. to confirm this look down thru the windsheild and you will see the spring laying in the hud.
Oct 17, 2010 at 10:36 AM
