2004 Pontiac Grand Prix codes
TAMLORNE
2004 Pontiac Grand Prix 6 cyl
Does anyone know what code 496 is for?
Thanks
Nov 19, 2008 at 11:10 AM
DAVE H
  • 13,383 POSTS
DTC P0496
System Description
This DTC tests for undesired intake manifold vacuum flow to the evaporative emission (EVAP) system. The control module seals the EVAP system by commanding the EVAP canister purge solenoid valve OFF and the EVAP canister vent solenoid valve ON. The control module monitors the fuel tank pressure (FTP) sensor to determine if a vacuum is being drawn on the EVAP system. If vacuum in the EVAP system is more than a predetermined value within a predetermined time, this DTC sets.
Nov 19, 2008 at 11:52 AM
