2004 Pontiac Grand Prix air blower
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
WEBERAGENT1
ONE DAY I STARTED MY CAR AND THE BLOWER FOR THE AIR AND HEAT STAYED ON AND WOULDNT SHUT OFF. SO I STOPED BY A GARAGE AND THEY UNPLUGED A WIRE AND SAID AS LONG AS IT IS UNPLUGED NOTHING SHOULD GO WRONG. THIS WIRE WAS AT THE BOTTOM OF THE DASH. i PLUGED IN THE WIRE A FEW DAYS LATER AND THE BLOWER NEVER TURNED ON BUT I HEARD LIKE A FRYING SOUND AND A LITTLE SMOKE SO I PULLED IT APART. THE CAR HAS BEEN RUNNING FINE AND IF I RUN AT HIGHER SPEEDS AIR GOES THROUGH AND IS COOLED BY THE AIRCONDITIONING OR THE HEAT WORKS. I JUST CAN NOT GET THE BLOWER TO BLOW OUT THE AIR. I WANT TO FIX IT BY MYSELF SO DO IN NEED A NEW BLOWER AND IF SO HOW DO I FIX IT AND WHAT MIGHT BE THE COST OF ALL OF THIS. A FEW MONTHS BEFORE IT WENT OUT IT SEEMED LIKE LEAVES WHERE STUCK IN IT AND IT WAS MAKING SOUNDS.
THANKS
AARON
Nov 20, 2009 at 2:08 AM
MMPRINCE4000
  • 8,548 POSTS
Most likely the leaves and debris have clogged up the blower motor wheel, binding it up.
You have to remove a good portion of the dash to replace it.
Best suggestion is to use car repair link in this thread or get a Haynes manual for instructions to repair.
This will also give you valuable info on brakes, fuel system and other repairs you can do yourself.
Nov 21, 2009 at 1:13 AM
CRAIG4465
  • 9 POSTS
I just replaced the blower on my 04 gtp , cost was about $95 . 3 clips and 3 screws and it drops right out. easy fix. i have read some issues about water getting in the blower. something about a leaking cowl or windshield. there is a filter between the outside and you blower motor so i disagree with the leaves getting in there. it took me about 1/2 hour to fix it. car has 120k on it
Nov 21, 2009 at 4:43 PM
MMPRINCE4000
  • 8,548 POSTS
Oops, thinking about the heater core rather than blower motor.
Nov 21, 2009 at 11:20 PM
