2004 pontiac grand prix
DOUGHBOY
I have a 2004 pontiac grand prix with 40,000 miles. The emmission light came on and is staying on solid. I read the owners manual and removed the gas gap a couple of time. Also ran a couple tanks of fuel through the car but it will still not go off. The car is running good, and the fuel economy is the same as before the light came on. Any Idea's
Thanks
Feb 2, 2006 at 12:29 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Provide any existing scan report or exact diagnostic trouble codes obtained for the warning light.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
CHEVY350GUY
  • 109 POSTS
this vehicle needs to be scan tested to retrieve the code(s) for the vehicles computer. this will help pin point the problem. this needs to be done first.
Feb 2, 2006 at 2:04 AM
SATRUNSL296
Atuzone has a free reader to decode the ECU signal. If its nothing important they can reset it also.
Hope it helps
Feb 2, 2006 at 2:17 AM
Discussion summary
The owner of a 2004 Pontiac Grand Prix reported a steadily illuminated emissions warning light. The car reportedly ran normally and fuel economy was unchanged. The light remained on after the owner checked the fuel cap and used a couple of tanks of fuel.
Reported outcome: The warning remained illuminated. No confirmed diagnosis, completed repair or resolution was reported.
No diagnostic codes were supplied. Normal reported performance does not identify the cause or establish that the warning can be disregarded.
Read the original discussion
