Thermostat the water pump and it is still getting hot?
NEWOYMMAT
  • 2004 PONTIAC GRAND PRIX
Our car got hot we changed the thermostat the water pump and it is still getting hot.
Monday, October 25th, 2010 AT 2:11 PM
  • 109,885 POSTS
This can be the result of a few things. Most commonly, it is due to a partially plugged cooling system due to corrosion. With that, I would start by flushing and refilling the cooling system.
Here is a link that explains the flush and refill procedure:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
If the system is clean already, the next thing to check is if there is an issue with a bad head gasket. If you look at the link below, it describes what to check for when suspecting a bad cylinder head gasket.
Sunday, September 5th, 2021 AT 10:03 PM
