2003 Pontiac Grand Prix Windshield wipers
70,000 MILES • 6 CYL • FWD • AUTOMATIC
SCOTTWOLLESEN
  • 11 POSTS
Guys, This is my first time useing this site. I think it is a great thing but I have been burned by similar "donation" sites. I have every intention of paying for quality advice so please understand my consumer caution.
My windshield wipers work fine on normal and high speed but are erratica and unpredictable on the delay settings. Sometimes they will delay perfectly for fifteen minutes then kick into normal speed for a while and back and forth on their own. The issue is with all delay speeds only, like I said, normal and high speed work fine. They also act confused, for a lack of a better word, for a moment trying to park when turned off from one of the delay settings. Any ideas? Thanks in advance for your expertice.
Scott
Mar 29, 2008 at 10:01 AM
SERVICE WRITER
  • 9,123 POSTS
Based on experience and description, the wiper control module that is located on the top of the motor is bad.
IF you have a DVOM, we can test the system.
36k-690k ohms is the value needed between the windsheild washer/wiper switch from the signal 1 circuit terminal to the accessory voltage supply circuit terminal in the switch side connector when you operate the switch through out the delay speeds from high to low.
If it isn't it needs a switch, if it is, it needs the module.
The module can be purchased aftermarket through NAPA and probably others for the same price as the module through the dealer, but you may want to verify that. I would put the whole unit on myself.
Mar 29, 2008 at 10:28 AM
SCOTTWOLLESEN
  • 11 POSTS
Unfortunatley I am weak in my knowledge of electrical trouble shooting and only have a pocket electrical tester. I am going to replace the module. It is only $50 and it makes enough sence that it is a worth while shot. Unfortunatly today I purchased the module in advance from the local Autozone....that had to ask me who makes the Grand Prix...got home, dug out the wiper motor and discovered they gave me the wrong part (go figure) and can't get the right one until the 3rd. So if the Pontiac dealer doesn't have one tomorrow i won't know if this works for a few days.
Mar 30, 2008 at 5:18 PM
SERVICE WRITER
  • 9,123 POSTS
Yeah the aftermarket has some modules. but that particular one is still in the making from what I have found. I believe dorman products has a part number but it is still in production and not released. I got burned the same way a month ago.
So it came down to a whole motor/module from napa or for a similiar cost the module from the dealer. The napa one had a lifetime warranty the module only a 12/12.
Mar 30, 2008 at 10:22 PM
SCOTTWOLLESEN
  • 11 POSTS
Oh really. Crap. Unfortunately the dealer AND NAPA were both closed yesterday (Sunday). Schucks said they did have a Dorman part number just like you said and if your right, only THINK they can order it.
Well I sure as heck hope it ends up being the control module and not the switch if I have to replace the whole motor/module.
I sure do appreciate your help
Mar 31, 2008 at 3:56 AM
SCOTTWOLLESEN
  • 11 POSTS
NAPA was able to order the module and receive it in one day. I installed it and now my wipers work perfect. Thank you so much for your help. This service is invaluable to military men like myself that can not afford $80 per hour in labor charges.
Unfortunatley I have only been given 0.3 points and a minimum of 1.0 is required to award your excellent service.
I will say that I would recommend Service Writer to anyone. Thank you so much for your assistance.
Scott
Apr 1, 2008 at 11:20 AM
MASTERTECHTIM
  • 4,750 POSTS
scott we appreciate people like you at this site, im going to donate 10 of my points to the service writer for you. keep up the good work, keeping us safe.
Apr 1, 2008 at 11:23 AM
SCOTTWOLLESEN
  • 11 POSTS
Thanks mastertechtim, pretty darn cool!
Apr 1, 2008 at 11:41 AM
SERVICE WRITER
  • 9,123 POSTS
Thanks, Tim and Scott,
Glad everything worked out well.
Good thing I guessed right :wink:
Apr 1, 2008 at 12:17 PM
