2003 Pontiac Grand Prix Windshield wiper fluid
80,000 MILES • 6 CYL • FWD • AUTOMATIC
KCSEPEGI
fluid does not come out of my windshield wipers. i can't even hear the motor run. any suggestions?
Mar 3, 2010 at 12:54 AM
MMPRINCE4000
  • 8,548 POSTS
Check for 12V at motor connector with wash ON, if voltage then replace motor, if not then fuse.
then either the fuse is blown or the motor is faulty or possibly loose plug, the motor is usually located at the bottom of the reservoir, just take a quick peek and see if its plugged in then if it is, then check the fuse, then if all checks out, change the motor, its very simple to change. pretty self explanatory
Mar 4, 2010 at 1:04 AM
