2003 Pontiac Grand Prix Misfires or torque converter
103,000 MILES • 6 CYL • FWD • AUTOMATIC
SISSY03
The car misfires on acceleration and bucks (possible engine miss) but when you hit accelerator and kicks down it feels like its in neutral and you can hear a wobble. Snap on scanner reads engine misfire on all cylinders and it also reads possible "TCC" (torque converter clutch) We have changed all spark plugs and wires and replaced all 3 coil packs with no change.
Jan 9, 2010 at 12:23 PM
MMPRINCE4000
  • 8,548 POSTS
TCC clutch may not be disengaging, but a Snap On scanner should tell you if PCM is commanding lockup.
If still misfiring, may be bad cam/crank sensor, or possible fuel pressure problem.
Jan 9, 2010 at 11:55 PM
SISSY03
What would cause the fuel pressure problem? What should I check before proceeding. I have already taken my car to a shop and they have no answer for me. The only thing that was showing up on the snap on scanner was the TCC code and all the misfires when accelerating. I really do appreciate all your help and time trying to figure this car out. Im getting so frusturated with it at the moment I just dont know what to do. Thanks so much!
Jan 10, 2010 at 1:59 AM
MMPRINCE4000
  • 8,548 POSTS
If TCC is problem, then they should repair it, but it could also be a fuel pressure problem (bad pump) or ignition (plugs, cam/crank sensor).
They should check all this out, especially if car is mis-firing.
Jan 11, 2010 at 12:34 AM
