Have heated leather seat on drivers side. Will not shut off.
Oct 13, 2010 at 8:39 AM
GMTECH
✓Experienced Mechanic
DO the seat automatically come one when you start the car? If so, perhaps check the wiring under the seat to see if you have any shorts to power or ground. Your switch may be stuck on as well. Try disconnecting the switch. If the seat is still on you have a short or a fried relay/ module.
