i have a 2003 grand prix gtp 3.8l supercharged v6 automatic. after i fill up with gas i go to start it will turn over but not crank. i try it again but have to give gas and then set there with foot on pedal cause if not it would die. even when i take off and slow it acts as if its gonna die. and it only does this that one time after filling up, all other times it starts right up no problem. and i only use premium gas. also theres a few times ive been sitting at red light and it will die out of nowhere but starts right up. also at times when idling it surges up and down a few times then stops. one other thing is when idling if you remove gas cap it starts surgeing til the cap is replaced. it has brand new fuel pump, charcoal canister from dealer. and replaced with new gas cap. so pretty much everything new around gas tank. im thinking its under the hood somewhere. and gas lines been cleaned out.
Apr 11, 2009 at 4:18 AM
