If your luck is like mine you will need to replace the multi switch/turn signal/hazard signal switch on the steering column. This original GM part is around $500. A non GM part is around $225. For dealer to put in is around $150. So, this is a $375 - $650 problem.
UNLESS you go to local junk yard/auto parts supplier. I found the GM part there from a car with only 48,000 miles for $80. Used this link below, with pictures, to put it on. Total cost = $80 and about 2 hours time.
Www. Clubgp. Com/cgi-asp/mods. Asp?Modid=141
mtucker@woh. Rr. Com
SPONSORED LINKS
Friday, November 23rd, 2012 AT 6:54 PM
