2003 Pontiac Grand Prix air flow sensor
DENISEMCGAUGHY
2003 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
What does the air flow sensor look like? Where is it located?
Dec 6, 2009 at 11:05 PM
MMPRINCE4000
  • 8,548 POSTS
It is in airstream to throttle body and measures the volume of air to engine, this info is used to set fuel and ignition MAPS. There are two different types depending on date of manufacture:
https://images.2carpros.com/forum/automotive_pictures/108325_MAF_GP_1.jpg
https://images.2carpros.com/forum/automotive_pictures/108325_MAF_GP2_1.jpg
You can buy a MAF cleaner at any autoparts stores, I would try to clean it before replacement. Also change air filter, if dirty, it will cause unreliable MAF output readings.
Dec 6, 2009 at 11:17 PM
