2002 Pontiac Grand Prix WINDSHIELD WASHER MOTOR
JGALVIN
Electrical problem
2002 Pontiac Grand Prix 6 cyl Two Wheel Drive Automatic
HOW DO YOU GET TO THE WINDSHIELD WASHER FLUID MOTOR TO REPLACE IT.
Feb 26, 2009 at 7:08 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated Hope this helps ... let me know Washer Pump Replacement Removal Procedure Drain the washer solvent from the washer solvent container. Remove the front fender liner. Disconnect the washer pump electrical connector. Disconnect the washer pump hose. Using a small flat-bladed tool, remove the washer pump from the washer solvent container. Using a small flat-bladed tool, remove the seal from the washer solvent container. Fig. 30: Washer Pump Courtesy of GENERAL MOTORS CORP.
https://images.2carpros.com/forum/automotive_pictures/266999_pont_2.jpg
Feb 26, 2009 at 12:32 PM
