2002 Pontiac Grand Prix wheel bearing assembly
159,000 MILES • 6 CYL • FWD • AUTOMATIC
LSLATE
My problem is having to replace the front wheel bearing assembly every 6 months to 1 year. What could be causing this? The shaft does not seem to be worn, am I putting them in wrong or what? This makes 4 or 5 times I had to replace both sides.
Mar 9, 2008 at 7:45 AM
SERVICE WRITER
  • 9,123 POSTS
What brand are you using?
What do you torque the axle nut to?
Mar 9, 2008 at 9:07 AM
BMRFIXIT
  • 19,053 POSTS
I agree with service write
make sure you have torque them correct
and I add
do you have any over size rims or tires
good luck
Mar 9, 2008 at 11:27 AM
LSLATE
Paul,
The brand we used this time was NTP and we torqued it at 180 FT #s, it does not seem to matter what brand it is, the very first one we changed was an AC delco brand which I do have to say it did last a little longer, but it also cost twice as much as the other brands.
And to anwer the other question, I have the same rims that came on the car size 16, and 225 60R tires.
Thanks so much for your input, maybe we can find a solution to this problem.
LSlate
Mar 10, 2008 at 11:39 AM
MASTERTECHTIM
  • 4,750 POSTS
replace the spindle. get one from a junk yard for 50 bucks and your problem will be gone. ive been there and its always the same, the spindle is distorted.
Mar 10, 2008 at 11:45 AM
