2002 Pontiac Grand Prix Hesitation
99,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHUMBLEY1
I have a 2002 Grand Prix and when driving down a highway/interstate, the engine sometimes hesitates/runs rough, like its gasping for power and you can see the rpm gauge fluctuating as this is happening. I have already replaced the spark plugs, added fuel injector cleaner and replaced the fuel filter. I have thought of a few other things it could possibly be but want an expert answer, thank you.
Nov 26, 2008 at 2:16 PM
MMPRINCE4000
  • 8,548 POSTS
If the ckeck engine light is on or not, have it scanned at any autoparts store for free, Look for hard or pending codes.
Check fuel pressure with a mechanical gauge.
Other possibilities are the ignition module, crank sensor, excessive EGR flow.
Is this the 3.8 or 3.1 V6?
Nov 26, 2008 at 11:35 PM
CHUMBLEY1
It is a 3.1 liter. I wondered if it could have been the o2 sensor or the idle air control valve or EGR issues. Thank you for the information and suggestions.
Nov 27, 2008 at 1:12 AM
MMPRINCE4000
  • 8,548 POSTS
It is possible that the O2 sensors need to be changed, I like to change them every 100,000 miles.
Never hurts to clean the TB and IAC as well as the EGR pintle and base, since they can accumulate a lot of soot.
Still, you want to make sure you have adequate fuel pressure, and have the ign. module tested. Also inspect the fuel pressure regulator vacuum line for signs of gasoline, if present, the FPR must be replaced.
Nov 27, 2008 at 4:57 AM
