2002 Pontiac Grand Prix Fuel Pump?
85,558 MILES • 6 CYL • FWD • AUTOMATIC
AUDRA12
My car wont always crank on the 1st try. I took the cover off of the fuel pump in the trunk and if you tap on it the car will crank. Could it need a fuel pump or relay or filter? where is the relay located? Thank You for any info!
Mar 3, 2008 at 11:28 AM
SERVICE WRITER
  • 9,123 POSTS
I think the terminology is a problem.
Crank (turn over) means the engine is trying to start, but doesn't.
No crank means nothing happens when the key is turned.
IS this a no crank problem or a no start problem?
Mar 3, 2008 at 1:05 PM
AUDRA12
no start!
Mar 4, 2008 at 11:27 AM
SERVICE WRITER
  • 9,123 POSTS
If you rap on the tank and it starts, there is a high probablity of the pump being bad. Relay should be in the engine compartment. If you change the pump, change the filter too..
Mar 4, 2008 at 11:28 AM
