2002 Pontiac Grand Prix Catalytic Converter
DARLENEK
  • 2002 PONTIAC GRAND PRIX
  • V8
  • FWD
  • 164,000 MILES
Hi
I was just advised that the catalytic converter needs to be replaced - cost $580.
Does anyone have any suggestions? E.G. Is there a product I could use to clean it out?
Does the car need a catalytic converter? I live in Canada.
Are they easy to take out if I don't need it?
Thank you so much.
Wednesday, March 4th, 2009 AT 1:21 PM
MMPRINCE4000
  • 8,548 POSTS
Depends on the Federal law in Canada. In U.S. It is illegal to remove or modify emmission devices.
You can replace with a universal type convertor, which usually run under $100 for the part.
My advice, replace it with either factor unit or universal. The O2 sensors will probably turn on the check engine light all the time without the convertor installed, engine will run rich and mileage will suffer.
Friday, March 6th, 2009 AT 8:45 AM
