2002 Pontiac Grand Prix broken spark plug
2002 PONTIAC GRAND PRIX
CATRINA*
Shakes or Wobbles problem
2002 Pontiac Grand Prix 6 cyl All Wheel Drive Automatic
I need help to remove broken spark plug
Oct 30, 2010 at 3:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Spray around the threaded area with a light penetrating oil like Liquid Wrench or Kano Kroil. Allow it to soak in for 20 minutes or more before trying loosen the broken plug. If this is the first spark plug that you attempted to remove, it's not a bad idea to soak the others. Usually if one is in poor shape, the others are probably not much better. Once you have decided that it has soaked enough, continue to the next step.
Get an EZOut the size that will fit the hole where the ceramic used to be. You will need a very large EZOut Extractor. An EZOut (or Easy-out) is similar to a drill, except that it turns in reverse. As you turn the EZOut counter clockwise, its teeth grip the interior more tightly and turns it.
Insert the EZOut extractor into the shaft where the ceramic part used to be. Make certain that the EZOut is the appropriate size. If it's too small, the teeth will not grip the sides.
Turn it very slowly and carefully to unscrew and remove the old spark plug.
Oct 31, 2010 at 1:53 AM
