I have the same problem with my 2002 Grand Prix as listed below. Any help would be appreciated.
Posted at Mon Sep 03, 2007 6:08 pm
By Frankenstein811, New to the forum
Give Feedback | Votes: 0
Hey Guys,
So I've seen a few other guys on here have the same problem I've got....so we'll try this one again. I've got a 2002 Pontiac Grand Prix 3.8L with 45000 miles on it, the problem is that the brake lights no longer work, however the 3rd brake light in the window does. And while messing with the hazard lights and steering column, I will get a flicker or two. I've researched this and found that most likely the problem is in steering column along with the turn signal switch...all of the wires are intertwined and hooked together...this is what I've gathered so far....can anyone tell me if Im on the right track or not, also this part that Ive come across is about $700...you may be able to pick it up for 500 somewhere, I will be writing General Motors(Pontiac Division) a letter describing the problem, I think this could be a recall thing...If I were anyone else on here I'd do the same thing.... Anyways, anymore help would be appreciated...
Thanks,
Justin
Find a manual for your Pontiac Grand Prix Repair Question.
Hey Guys,
Thanks,
Justin
Dec 22, 2007 at 3:04 PM
